MSN Messenger
25 Dec 2002
Brighton
Im looking for a way to delay the start of MSN messenger, with my PC now booting so quickly messenger starts before my network connection so it doesnt auto sign in.
I have MSN running in compatibility mode also as I couldnt get used to it on my task bar and not in the tray.
Tried the "sign in automatically when i am connected to the internet" combined with the start when windows logs in.. Ive never tried, but one would assume it would start with windows and then start once connection comes available.. but this is msn after all, so im probably wrong haha!
You could put a script in the startup folder that waits for a while and then starts Messenger (although it's been Windows Live for quite some time! 'MSN' is what the parents of teenagers call it).
I don't know how, but I'm sure it could be done with a script.
I had a quick go at this:
Code:
@ping 127.0.0.1 -n 10
START msnmsgr.exe
Saved as a .bat, put in your startup folder. Though you will see the command prompt window as it pings 10 times. Seems there is no WAIT command so ping a few times to make a delay instead.
There is almost certainly a better way to do it.
A slight amendment to the above (direct the ping output to NULL device to stop the cmd window filling with faff).
Code:
@echo Delaying MSN startup, please wait...
@ping 127.0.0.1 -n 20 >NUL
@start msnmsgr /background
Don't forget to disable "Automatically run Windows Live Messenger" in its options!
Or there's this :p
Edit:
Rather than putting the .bat in your startup folder, create a shortcut instead and put that in there, then set the properties of the shortcut to run minimized.
