ANTEC THREE HUNDRED ULTIMATE GAMING CASE - LOWEST UK PRICE
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
One of the all time best selling cases is now available for a great new low £40.98 - only at Overclockers UK.
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £40.98 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for all the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Only £40.98 inc VAT.
ORDER NOW
Excellent case. I bought mine from OCuk when they were on same for 37 pounds but this is a good deal nonetheless.
I reccomend it to anyone that doesn't have a massive Graphics card, although i heard you can fit a 5970 in it by taking the top HDDs out.
The case will fit a 5870, not a 5970. But if you remove the HDD cage you can fit the 5970 - but thats having to mod the case.
