- 17 Dec 2008
Hi, I trying to find parts for water cooling when I get money to buy them.
Can anyone suggest any parts or tips.
The bridge has already got a water block for watercooling system with 3/8" ID tubes or for system with 1/2" or 10mm ID tubes.
I'm thinking of getting two or one GTX 470 gpu's.
I had to remove the back plastic cover for the HDD raid sata connectors because of the bending of the connectors.
So I used a different cable, so the cover won't be able to fit.
Would something like on image work?
What size tube do I need?
I'm using a Striker II Extreme motherboard that gets quite warm.
Thank you
Thank you
