Open a terminal window and type the following (case sensitive):
Code:defaults write com.apple.finder AppleShowAllFiles OFF killall Finder
You've set it to show hidden files somehow, this will correct
that.
And you can change a parameter to stop OS X creating the files on a mounted network volume.
Try this, Mark.
Code:defaults write com.apple.desktopservices DSDontWriteNetworkStores true
adscan, have you done the terminal commands posted previously and they're still appearing?
