Post your idle temps
i have a corsair with one fan and the rad does need a clean as well.
Sat idle at 19 degrees using a MegaShadow with Sharkoon SE 1KRPM Push/Pull.
I start up MW2 and they jump to about 35 degrees, quite good actually :D
A little cooler today - idleing at 43c avg , a bit less then yesterday
Went onto cod mw2 for 20mins and OUCH
Never touched over 63c before (even with a 100% load on) or over 73c on my gpu
My i7@4GHz idles around 43c to 47c. Room temp is 28c to 29c :/ Played a game of tf2 for a few hours earlier and max temp hit 66c. My max temps from winter aren't too different with my H50 in push/pull, its just my increased idle temps, which is to be expected as its watercooling.
Edit: Just checked my q9550 E0@ 3.83GHz and that's idling at 34c to 39c with a Titan Fenrir. It is downstairs though where it is slightly cooler.
19c? what cooling are you using because even using water cooling I find that hard to believe.
Also this thread is useless wihtout people telling us what utility they are using to monitor their CPU temps as some of them can be radically inaccurate.
What utility are you using to monitor temps?
My Q9550 idles temps,
Averaging around 31c across all cores : Core Temp & Real Temp
Ambient Temp 23c
