Just sent wife off to B&Q to purchase air con unit......![]()
It's quite clear the OP needs more than a fan to dissipate the excess heat in the room. A fan would be okay in a normal room without a PC generating a lot of heat, with the PC, you have to remove the PC or air condition the room somehow if it's really that bad.
even though you lose most of your body heat through your head.
