are my eyes playing up??
5 Feb 2009
N. Ireland
just noticed that the smilies, 'trust' 'quote' buttons etc along with a few bits and bobs on some other websites are slightly 'blurry'. also the txt seems a bit bigger on the forums on my screen. don't think i've made any setting changes that could have done this, least none i can remember!! i was messing about in CCC, tho not sure if i could have done summat stupid in there that could have caused this?
anyone experienced this or any ideas how to fix, sorta feels like possibly the resolution or frequency aint right but they're both still at their normal (1920x1080 @60hz)
windows 7 64. dont think its to do with clear type, never went near it, just turned on yesterday and noticed it, but just thought it was down to a heavy weekend and my eyes being tired!
Mine aren't the greatest of clear qualities, but are certainly aren't too blurry :)
its not that mine are particularily bad, just that they have definitely changed, had also thought maybe OcUK had made some changes to their forums but i'm seeing it on other websites too
are you using IE8?
have you accidentally zoomed in slightly? (ctrl+scroll wheel)
look in the bottom corner of the browser for the magnification setting
oh dear god, face and palm spring to mind, i've un-installed and re-installed gpu drivers about 10 times trying to fix. think i should stick to the xbox!!
cheers :o
