Hi I am currently looking to replace my 3 120 m sharkoons on my pa 120.3 which is mounted horizontally at the top of my 700d.
After doing some research it seems like sleeve bearing fans should not be mounted vertically, i.e. blowing air up or down. This was news to me as my sharkoons have been mounted that way for a long time. Allegedly any reduction in noise which would normally be accounted for by using a sleeve bearing fan can be negated by not mounting them horizontally, i.e. they should be blowing left or right.
As most silent fans seem to be sleeve bearings has anybody any experience of using ball bearing fans in a vertical position on a pa 120.3. If so which ones?
Sorry after reading more it seems that rifle bearing fans or fluid bearing fans may be the quietest and best suited fans for rads. Do these even exist for pcs?
cheers
cheers
