What to do?
Caporegime
6 Dec 2005
Birmingham
Right I've got an exam tomorrow...Sports and Exercise Medicine (it's a new module so no past papers) and basically the exam is 100% of the module and we have got a seen question which is worth 50% of the whole paper, has to be in essay form with references etc and we have been told we should spend around an hour writing it. It's not open book, so can't take any material in or anything like that.
Now then the work I've done so far I feel is pretty good and I'm quite confident I can do well, but I've just been looking for some other research for the seen question and I've found two papers which are superb. It's a review study so there is lots of info (about 20 pages each) and references (204, in Part 1 alone). We've been told that 25 marks will be attainable from "the ability to cite the relevant literature where appropriate." I'm guessing the question will be 60 marks in total, so getting references for info is key for this!! :(
The question is, seen as it's 11PM at the moment and my exam is in the morning, should I take the chance of staying up late / all night condensing and revising the info and references from these papers to give me some kind of super answer? Is it worth it or should I just be content with what I have in my head at the moment and go to sleep?
Sleep is essential to perform properly in an exam. Go get some.
If you feel like it you can always get up early and refresh the new material in the morning. You'll take it in better when your brain is awake.
I'd stay up and revise, but I do better in exams running on adrenaline and knowing more than being rested and missing out on 12 hours revision.
At this time now, i'd say sleep.
Depends how you're feeling confidence wise, if OK sleep, or spend 30 minutes condensing some stuff if it makes you feel better when you go to sleep (i.e; dont want to lay there thinking about it all night and not sleep).
Good luck :)
Bugger, that's unlucky. Trouble is exams are finishing around now so everybody's getting mashed.
You've now got a choice to either stay up or go to bed for 7 hours. Only you know what's the best option; good luck!
