- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
23 new amazing deals available This Week Only, offering selected products all substantially reduced in price for a one week period.
AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz (Socket AM3) - Retail @ £127.98 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.20GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Only £127.98 inc VAT.
ORDER NOW
Antec 1200 Twelve Hundred Ultimate Gaming Case - Black @ £114.99 inc VAT
The Antec Twelve Hundred is the evolution of the best-selling Nine Hundred, expanding on its award-winning design with even more cooling, capacity, and convenience. The Twelve Hundred is incredibly robust, with 12 drive bays, 7 expansion slots, and space for even the largest graphics cards. To keep the most demanding systems nice and cool, the Twelve Hundred boasts an unprecedented cooling system, with a top mounted 200mm blue LED fan, two rear blue LED 120mm fans, and three front blue LED 120mm fans to cool the HDD cages. Factor in convenient features like front mounted USB, eSATA, and HD audio ports, and the Twelve Hundred obliterates the competition.
- 12 Drive Bays
- 7 expansion slots
- Advanced cooling system
- No power supply included
- Motherboard: Up to standard ATX
- Top mounted I/O ports for easy access
- Perforated front bezel for maximum air intake
- Washable air filters reduce dust build up in your system
- Convenient top accessory tray for a personal media player
Only £114.99 inc VAT.
ORDER NOW
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) @ £62.98 inc VAT
The Corsair Cooling Hydro Series H50 CPU Cooler gives you the power of liquid cooling in a compact, easy-to-install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
Air-based CPU coolers simply aren’t as efficient as water coolers, and can take up too much valuable space. The compact, closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.
- Supports LGA775, 1156, 1366, AM2, AM2+ & AM3
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large 120mm radiator for fast heat dispersion
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator
- Two-year warranty
Only £62.98 inc VAT.
ORDER NOW
Intel Core i7 980X 3.33GHz (Gulftown) Extreme Edition (Socket LGA1366) - Retail + Napoleon Total War @ £853.26 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA1366
- Six Core
- Frequency: 3.33GHz
- Multiplier: 25x
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- QPI: 6.4 GT/s
- TDP: 130W
- Includes Heatsink & Thermal Paste
Only £853.26 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 Low-Voltage Dual Channel (OCZ3G1333LV4GK) @ £89.98 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Only £89.98 inc VAT.
ORDER NOW
OCZ Gold 6GB (3x2GB) DDR3 2000MHz PC3-16000C10 Low-Voltage Triple Channel (OCZ3G2000LV6GK) @ £168.99 inc VAT
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel Core i7 processor / Intel X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 2000MHz DDR3
- CL 10-10-10-20 (CAS-TRCD-TRP-TRAS)
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Only £168.99 inc VAT.
ORDER NOW
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply @ £67.99 inc VAT
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 140mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- up to 86% Efficiency
- Overvoltage/OverPower/Short-Circuit protection
- (.99)Active PFC
- MTBF: 100,000 hours @ 25C
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
Only £67.99 inc VAT.
ORDER NOW
OCZ Vertex Limited Edition 100GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTXLE100G) @ £279.99 inc VAT
OCZ Technology’s latest ground-breaking solid state drive is taking shape in a limited edition solution designed for consumers looking for the highest level of SSD performance. Pushing the envelope like never before, the OCZ Vertex Limited Edition surpasses the competition where it counts most: maximum read/write speeds, unparalleled 4k random write rates, and minimal performance degradation. With performance that takes centre stage, the Vertex LE series doesn’t lose sight of what makes an SSD the ideal storage alternative to hard drives and delivers the quality, reliability, and durability demanded by consumers that will not settle for anything but the best. Complete with TRIM support, Vertex LE is the ultimate Windows 7 notebook or desktop upgrade.
- Capacity: 100GB
- Maximum Read: 270MB/sec
- Maximum Write: 250MB/sec
- Sustained Write: 235MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-II
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £279.99 inc VAT.
ORDER NOW
Patrtiot G Series Sector 5 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel (PGV34G1333ELK) @ £87.98 inc VAT
The Patriot G Series 'Sector 5' edition, part of the Extreme Performance (EP) Enhanced Latency line, is engineered to expand your gaming options for the Intel® 5 platform. These parts are engineered for maximum performance and stability under extreme overclocking conditions. The G Series 'Sector 5' edition are built with quality and performance in mind and are the ultimate solution for extreme overclockers, gamers and PC enthusiasts. Equipped with lightweight aluminum heat-dispersing shields these modules are engineered to run at 1333MHz with 9-9-9-24 timings, available in 4GB kit and comes with a lifetime warranty.
- Extreme Performance PC3-10666 (1333MHz)
- Enhanced Latency (9-9-9-24)
- XMP Ready
- Equipped with advance aluminum heat-dispersing shields
- 100% Tested and Verified
- Lifetime Warranty
- RoHS Compliant
- Tested on Intel® 5 chipset
Only £87.98 inc VAT.
ORDER NOW
Prolimatech Megahalems Rev B CPU Cooler (Socket 775/1156/1366) @ £42.98 inc VAT
The tower type coolers have been the mainstream in the CPU cooling market for quite some time now, but upon closer inspection you start to notice that designs and engineering can only go so far as they are slowly come to a bottleneck. After a while they all start to look the same with performance not worth popping the champaign. This is where Prolimatech comes in. We are here to challenge all possible odds and stray away from the norm. With that focus in mind comes the new Megahalems, tower CPU cooler. Never before seen are the new lows in temperature produced by an intelligent design of low air flow resistance with unmatched performance to boost; perfect for the true overclockers in all of us.
- Heatsink Dimension (L)130mm X (W)74mmX (H)158.7mm
- Heatsink Weight 790g
- Heatpipe Ø 6mm X 6pcs
- Suggest Fan 120mm X 120mm X25mm
- Suggest Fan Speed 800~1200rpm
- Suggest Noise Level (dBA) Below 26dBA
- Direction of heatsink faces the rear exhaust system fan
Only £42.98 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 5750 Vapor-X 1024MB GDDR5 PCI-Express Graphics Card @ £109.98 inc VAT
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition. The Vapor-X cooler runs cooler and more quietly than other solutions, increasing reliability and allowing enthusiast users significantly greater headroom for performance tuning.
- Core Clock: 710MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4640MHz (Effective)
- Processing Cores: 720
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
Only £109.98 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 5970 2048MB GDDR5 Graphics Card @ £479.99 inc VAT
The fastest graphics card on the planet, the ATI Radeon HD 5970 delivers an unrivaled HD gaming experience so you can play the latest, most demanding HD titles like never before. Engineered for speed, this next-generation powerhouse delivers unprecedented performance straight out of the box. Unlocked, this graphics card has massive headroom so you can take control and push your hardware to its full potential! Expand your visual real estate across up to three displays and get lost in the action with ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. Among the first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals with explosive performance so you can dominate your gaming competition.
- Core Clock: 725MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 256GB/s
- Processing Cores: 3200
- Display Connectors: 2 Dual-Link DVI-I & 1 Mini DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £479.99 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £79.99 inc VAT
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Warranty: 5 Years
Only £79.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 4850 512MB GDDR3 Dual DVI (PCI-Express) - Retail @ £67.99 inc VAT
Featuring a full TeraFLOP of compute power, the XFX Radeon HD 4850 is true power player. The single slot design enables easy three- and four-way CrossFire assembly. Play the most intense games with a graphics card that knows how to conserve energy while delivering optimum performance.
- Bus Type: PCI-E 2.0
- GPU Clock: 625 Mhz
- Memory Bus: 256
- Memory Type: DDR3
- Memory Size: 512 MB
- Memory Speed: 1990Mhz
- Outputs: HDTV, Dual-Link DVI
- TeraScale Graphics Engine
- Unified Superscalar Shader Architecture
- Accelerated Video Transcoding (AVT)
- Dynamic Power Management
- 800 Stream Processing Units
- ATI PowerPlay™ Technology
- ATI CrossFireX
- DirectX 10.1 Support
- HDCP Capable
- Feature: TeraScale Graphics Engine, ATI PowerPlay™ Technology, ATI CrossFireX, - DirectX 10.1 Support
- Package Contents: DVI Adapter, HDTV Component Adapter, 6 Pin Y Power Cable
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA/ testing terms and conditions (http://www.overclockers.co.uk/support.php)
ORDER NOW
Samsung B2430H 24" Widescreen LCD Monitor @ £169.99 inc VAT
Samsung 30 Series monitors are designed to be eco-friendly as well as user-friendly. With efficient power saving and innovative features, they allow you to enjoy using your monitor with the confidence of a clear conscience. The phenomenal 70000:1 Dynamic Contrast Ratio welcomes you to a world of intense, natural colour and incredible, lifelike detail. Combine that with a high brightness of 300cd/m² and you have a monitor that is made for multimedia.
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 70000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 582.0mm x 448.0mm x 197.0mm
- Weight: 5.1kg
- Warranty: 3 Years On-Site
Only £169.99 inc VAT.
ORDER NOW
Creative Fatal1ty HS-800 Gaming Headset (51MZ0310AA001) @ £29.99 inc VAT
Creative's Fatal1ty Gamer Headset provides power, precision and comfort for the serious gamer. The ergonomic, lightweight design, with padded velvet earpieces and headband, ensures a comfortable fit during extended gaming sessions. Weapons, positional cues and environmental audio effects sound fantastic through the high-quality drivers, with excellent bass response for powerful explosions. The noise-cancelling microphone transmits voice commands clearly to other team members, and it can be detached for easy storage or to use the headset like regular headphones. In the heat of battle this is the headset that won't leave people stranded - and that's why Johnathan 'Fatal1ty' Wendel, the world's best known pro gamer, uses it.
- Ergonomically designed and acoustically tuned for gaming.
- Padded headband and earpieces for ambient noise exclusion and comfort during long gaming sessions.
- Swivel joint earpiece design adapts to every user.
- Detachable and adjustable noise-cancelling microphone.
- In-line external volume control with microphone on/off.
- Excellent response for voice communications and dynamic in-game audio, with extended bass response for high-impact explosions.
Only £29.99 inc VAT.
ORDER NOW
SpeedLink Medusa NX 5.1 Gaming Surround Sound Headset (SL-8793-SBK) @ £46.99 inc VAT
Find yourself right at the centre of the action with this 5.1 surround headset: hear a door closing behind you to your left or listen to the footsteps of your opponent who’s in front of you. Plug the Medusa into the 5.1 soundcard on your PC or using the phono adapter and mains adapter, into your DVD player.
- Real 5.1 gaming surround sound
- Real all-rounder - can be used on all sound sources
- Brilliant voice transmission
- Highest level of comfort
- Adjust sound channels individually
- Collapsible headset including carry case
- 3.8m cable
Only £46.99 inc VAT.
ORDER NOW
Microsoft Windows 7 Home Premium - Retail (Full Version) @ £92.99 inc VAT
PLEASE NOTE: This is the full retail version and does not require a prior installation of Windows as per the upgrade version. Both 32-bit and 64-bit discs are included.
Windows 7 Home Premium offers a rich, dynamic entertainment experience on your PC, making it easy to create a home network and share all of your favorite photos, videos, and music. You can even watch, pause, and rewind TV or record it to watch whenever and wherever you want.
- Record TV on your PC: Watch, pause, rewind, and record TV, movies, and other video content with Windows Media Center, updated to manage a single TV guide containing both standard and digital high definition TV shows.
- Personalise your desktop: Easily change backgrounds, window colours and sounds to reflect your personal style. You can even turn your desktop into a slide show of your favorite photos.
- Share files across the various PCs in your home: Use HomeGroup to connect your PCs running Windows 7 to a single printer. Specify exactly what you want to share from each PC with all the PCs in the HomeGroup.
- Pin any program to the taskbar: Any program is always just a click away - and you can rearrange the icons on the taskbar just by clicking and dragging.
- Stream music files on any network-connected device: Just open Windows Media Player, right-click on what you'd like to hear, select Play To, and you'll see a list of devices and PCs on which you can play your music.
- Find virtually anything on your PC - from documents to photos to e-mail: Just click on the Start button, and enter a word or few letters in the name or file you want into the search box, and you’ll get an organised list of results.
- Access recently used files with just two clicks: Right-click the relevant program icon (such as Word) on your taskbar and Jump List will show your most recent, frequently used, and pinned Word documents.
Only £92.99 inc VAT.
ORDER NOW
