EK GTX480 back plate
10 Apr 2004
Weston-Super-Mare
Hi have just purchased a EK Acetal water block for GTX480, it is worth ordering the back plate from EK?? as I've seen reports of the card bending when using this block,, or is there a better and cheaper method.
just got two delivered so installing them this weekend. will report back.
luckily my Lian Li P80 case has an extra bracket to support the graphics cards, which will support some of the weight, cos these blocks weight a tonne :D
Well fitted the EK block to day, leak testing it the moment,, have to say it is heavy but so far no real signs of bending yet, will keep an eye on it..
