I use Castrol Spray Lube/Wax and its not bad. I see a lot of good reports for the Wurth spray that Mr.E has suggested. Only thing it looks like its not lubed with the spray so you wonder if it needs more!
May try and get some of that. The current lube I'm using does have quite a bit of flick in it, which is a bit irritating after spending ages sorting the bike.
Im currently using Muc off stuff. was advised to put it on after a run so it has a chance to penetrate. appears to work as my back wheel isn't covered in carp.
If you do high miles they are fantastic. I miss mine and will get another. You have to adjust the flow rate depending on the temperature, but they keep the chain in very good nick and don't fling if adjusted appropriately.
