Ive decided I want to buy a air cooler, atm Im using a fan to keep my ferrets cool on hot days, but I want something to cool the room. Because on hot days, my room isnt too bad until late after noon, then all of a sudden the temp will shoot up, and temp will keep climbing untill likle 12-1am, its crazy, cos I would have thought the temp would drop in the evening. The max temp its got in my room is 32c over the summers, and thats far to hot for me, let alone the ferrets, but their not to bad cos they have a fan.
So its between these 2 air coolers
PREM-I-AIR MAC345 MINI EVAPROTIVE AIR COOLER/CONDITIONER WITH FAN + 500W HEATER
Specs
# ideal for your desk or table
# Incorporates a 500W heater for all year around usage
# Easy fill tank for water & ice
# 3 speed fan
# Water level indicator
# Tank capacity 0.5 Litre
# Safety tip over cut-out.
# Power: Cool 20W
# Heat 500W
# Voltage: 230V ~ 50Hz
# Dimensions (WxHxD) cm: 21x25x23
Portable Air Cooler/Air Purifier Unit
Specs
Black and Silver design.
* Only 80 Watts (Cheap on Electric).
* 3 speed fan.
* 1.5 Liters water capacity.
* With 27cm x Height 69.5cm x Depth 36.5cm
* Mobile unit on wheels.
* Air purifier.
* 0.5 to 7.5Hour timer.
* Rotating blades.
* Remote with batteries.
* 2 ice packs included for even cooler air.
* Use scented oils in water for fresh smell.
I would like to buy the small 1 due to having nowhere to really store the larger 1. But the small 1 is only 20watts and the large 1 is 80watts.. I guess im a fool if I go for the small 1, I have about a 3 - 5 meter sqr room to cool??
Specs
# 3 speed fan
# Power: Cool 20W
# Heat 500W
Specs
* 3 speed fan.
* Air purifier.
* Rotating blades.
