Gulf Oil Spill ( LIVE FEED )
http://i.dailymail.co.uk/i/pix/2010/05/26/article-0-09BCB0E7000005DC-567_468x729.jpg
http://www.bp.com/liveassets/bp_int...local_assets/images/TopKill_5-21_1a_large.jpg
see the broken riser, cant they undo, remove the broken pipe then attach with new pipe, use ROV to bolt down, oil stream up onto the tankers. i know it wont be permanent fix but at least it wouldnt take long. better than leaking oil into sea!
Thereby removing the one restriction left to the oil flooding out
holy mcsheeez! Is that real? As in all pumping out right now?
Anyone else fancy a dive with several hundred barrels? 71 bucks a barrel!
Most of that looks like the mud and cement mix used for the top kill, hopefully that means it's working as in previous views the mud was overwhelmed by the oil leaking out, now it seems the other way round.
Latest news:
A BP official said he believed mud, not oil, was exiting the well's ruptured pipe six hours after the work began.
"What you've been observing coming out of the top of that riser is most likely mud," BP Plc chief operating officer Doug Suttles told reporters in Houston.
"We can't fully confirm that because we can't sample it. And the way we know we've been successful is it stops flowing."
Company officials say it could be a couple of days before they know whether the "top kill" operation has worked
Source
Let's hope that it is working.
I just can't imagine the engineering involved, trying to get a mud/cement mix to solidify in water at that depth whilst also withstanding the pressure of the oil flowing out of the ground...you'd think that the second the mix exited the pipe it would just be blown out into the ocean. Plus afterwards it's got to be solid enough to be a (semi)permanent solution so that it just doesn't blow out again.
I do feel sorry for BP a little bit (but not a lot) they're working hard to stop the flow, it's not like they want this to get worse...in a parallel world where the blowout didn't happen this would have been a really good find and their share price would have increased...instead it's dropped 25% and they're going to spend billions in the cleanup :p fate is a cruel bitch sometimes.
8.4% yield on what? Bonds? Over what time frame? 1yr?
Dividend to share ratio.
Ie if you invest £1000 you will get back £84 in dividends over the course of a year (BP pays 4 dividends per year - 1 per quarter).
Better than any ISA :p
Anyone already owned them for a year who can confirm what they paid, sounds a bit too high. I believe they yield the same as shell who have suffered the loss of alaska drilling potentially because of bp
2ndUPDATE:BP Shares +6% As Coast Guard Says Gulf Leak Stopped
(Adds details on oil spill volume.)
By James Herron
Of DOW JONES NEWSWIRES
LONDON (Dow Jones)--Shares in BP PLC (BP) rose sharply Thursday as U.S. Coast Guard Admiral Thad Allen, who is overseeing the disaster response in the Gulf of Mexico, said the company's "top kill" maneuver had successfully prevented oil and gas leaking from the well.
But the good news was tempered by the first official acknowledgment that the amount of oil that has been gushing from the well for over a month is much larger than initially estimated.
At 1509 GMT BP shares were up 5.8%, or 28 pence, at 520p in a broadly stronger market.
Allen told a New Orleans radio station that BP's "top kill" operation to plug the leak has "stopped the hydrocarbons from coming up," the well. However, he cautioned that the operation to seal the well permanently was not complete.
The key now, Allen said, is whether the heavy drilling mud BP is injecting into the well exerts enough sustained pressure for engineers to move forward with an operation to cement and seal the wellhead.
"The goal is to put enough mud down the well bore to the point where there is no pressure exerted back by the hydrocarbons and then allow a cement plug to be put in place," Allen told the radio station.
A BP spokeswoman said "operations are continuing," but declined to comment on Allen's statement.
Offsetting the positive news, a federal team created to study the flow officially put the leak rate at 12,000 barrels to 19,000 barrels per day, U.S. Geological Survey Director Marcia McNutt said Thursday. This compares with the previous official estimate of 5,000 barrels a day of oil.
The team also calculated the amount of oil on the surface as of May 17 to range between 130,000 and 270,000 barrels. A similar volume of oil had already been burned, skimmed or evaporated, McNutt said in a conference call.
This figure is crucial for BP, which could face a maximum civil penalty of $1,100 per barrel of oil spilled. This figure can rise to a maximum of $4,300 a barrel in cases where gross negligence is proven.
Oil has been leaking from BP's damaged Macondo well since an explosion that destroyed the Deepwater Horzion rig operated by Transocean Ltd. (RIG) on April 20. Oil has contaminated Louisiana beaches and marshes and killed wildlife.
2.4bn in fees plus costs?
I've owned them for 4 years.
Dividend has not been missed in that time.
Shells is 6.something %. I can't find the Bloomberg report i read earlier.
