hmm i didn't know you could damage an mcom like that, i thought you HAD to walk in and plant a bomb (press E) i dont play mcom that much i play conquest mainly![]()
Everyone that plays the game has their own stupid little tactics on each map, and every time they play they use the same tactics and go the same way, the fun part was learning your tactics then putting them to use over time. When the game plays out exactly the same each time it's just tedious, with BF2 the maps were always diff, there was never something which made each round similar to a previous 1, each 1 was new, different and had a new tactic you would try.
Mcom damage can be turned off on some servers though......I think
But destroying a building with one inside will always do the job.![]()
so will destroying all the outer walls blow the mcom up then?lol maybe i should play mcom more oftenso will destroying all the outer walls blow the mcom up then?
That is the quote of the thread
Then again I play as a wookie with C4 and the SVU or the other rapid fire one
Ok, that may have been coz I wasn't using the spas 12 with magnum and the long range slugs, just did a 30-5 as a wookie
Including a tripple c4 kill of 3 ppl in 1 tank thingy
Still, think i ended on about 35-15 ish with the top score (Conquest).
is there an award for finishing a round with 15-0?
