Caporegime
- 9 Nov 2009
- Planet Earth
OTH,if you can get a better graphics card within the same budget with an AMD based system it would mean you would need to upgrade the graphics card less often.
dose anyone know if this amd "bulldozer" cpu will be am3 or somthing new like am4?
Personally I'd go 5850 whichever cpu I went for...
£886.69
. . . Do you think a single HD5850 would be laggy? . . . do you need the most expensive AMD motherboard in the world?
Monster ninja, you clearly got more money than sense!. . . Do you think a single HD5850 would be laggy? . . . do you need the most expensive AMD motherboard in the world?
I can't say spending £449.98 on a pair of Radeons is really needed? . . .wouldn't it be wiser to start off with a single card and see how you get on? . . . . the System-Core below is hot-to-trot and saves you £332.57 which could be put towards something more meaningful!
...but just think of the power of two of them underwater and overclocked!!!!!!!!
that mobo looks so ugly!
. . . well theres no accounting for taste! . . . looks sweet to me and will get the job done in style!
i like ROG 4 16x lanes!
its still £50 then an i7
i will only get one 5850 for now
why not reaper ram?
You know I have to agree with you here but are you seriously gonna pay for sex?it may be the most expensive AMD motherboard in the world but it is the sexyest AMD motherboard in the world!![]()
According to this article AMD Bulldozer should be on socket AM3:
http://www.anandtech.com/show/2871/2
Unless Crossfire at PCI-E.0 16X/16X is important I would get the Gigabyte motherboard which does Crossfire at PCI-E 2.0 8X/8X. The Asus 890GX motherboards are also meant to be good and also are better for overclocking IIRC.
Your just throwing money away like its going out of fashion? . . . the whole point of choosing AMD is to get great performance *while* saving money (i.e Bang-For-Buck) . . . not to choose a £160 motherboard mainly aimed at Benchmarkers and Techno-Nerds attempting a world-record overclock!![]()
"only" a HD 5850, wow man your so lucky to be able to own a HD 5850, seriously that cards rocks da house, your very lucky!![]()
DDR3-1600 Cas 7 is awesome although not that much better than Cas 8 . . . I was thinking along the lines of DDR3 doesn't really run hot so why would you need big mama heatsinks? . . . they will most likely clash with a 3rd party CPU cooler should you get one . . . feel free to plurge £25 extra on something your not gonna notice . . . .
also i am now using a corsair H-50 for my aftermaket coolerYou know I have to agree with you here but are you seriously gonna pay for sex?![]()
for a good looking rig this time somthing that looks very cool i am also going to powercoat my case cold cathoids,ect
dont get me wrong i have seen worse looking mobos but i dont like the colour of the PCB its self and you cant have 2 lines in 16x.. also its not an 800chipset with no sata 3/usb3 somthing i really wanted so its also not as future proof.at the end of the quotes instead of this
i feel so stupid...Have you considered on of the 890GX based motherboards? They do Crossfire at PCI-E 2.0 8X/8X and this should be fine AFAIK!
Also the newer batches of the Samsung F3 have issues with the SB850 southbridge:
http://forums.overclockers.co.uk/showthread.php?t=18148038
Samsung have provided a firmware update for affected drives though.
damn it! i got my self a f3 about about november/december 2009 will they be affected to? i was going to get a ssd with this rig
IIRC,the issues was to do with SMART or something along those lines so earlier drives hopefully won't be affected.
OTH,the Asus Crosshair IV has as a single SATA 2.0 port running off a JMicron controller so you could use this port instead.
so much for buying a few more spin pionts then
