- 30 Jun 2008
Hi everyone
I just wanted to share my overclocking experiences on my HP nw8000 Mobile Workstation
Made back in April 2004, this laptop has a 1.8GHz Pentium M Dothan 2MB processor, with a 400MHz FSB. The laptop's chipset is an Intel i855PM, which is only rated to do 100MHz FSB.
I tried using ClockGen and SetFSB, but they didn't support my Clock Generator (ICS950810). In fact, this Clock Generator can't be changed using software at all. So I got the datasheet and found that I could run it at 133FSB by joining pins 54 and 55.
So I did that and my CPU was now running at a 133MHz FSB, but that brought on it's own problems. First, the CPU didn't have enough voltage to run at 2.4GHz (1.34v default max), so I used a Pentium M Voltmod by shorting 2 pins on the processor to get it up to approx 1.59v. That made it fully stable.
The other problem was the RAM (DDR333) couldn't run at DDR433 which would be the new setting due to the overclock, so I had to reprogram the SPD using SPDTool to make the RAM think it was DDR266. This would trick my motherboard into running a 3:4 ratio instead of a 3:5 ratio, and that basically meant the RAM was now running at DDR354, which it can handle. I also had to reprogram the SPD to make it run at 2.5 CAS instead of 2 CAS.
So yea, everything's running good now, just thought I'd share that with you so that you know it's possible to do. I'm happy SetFSB and ClockGen didn't work, because if they did I would be happy with something like 110FSB or whatever this would reach without volt mods and with raised AGP/PCI clocks, but thankfully they didn't work with my laptop so I was forced to look for something more extreme. I think it's possible to overclock any laptop, although sometimes you'll need hardware mods (in my case everything was hardware based except reprogramming my RAM).
If you're looking for results (I know Windows Performance Assessments aren't the best benchmarks but it's the only thing I could be bothered for!):
CPU-------- 3.4 => 4.1
Memory----- 4.1 => 4.3
Graphics 1-- 3.6 => 3.6
Graphics 2-- 3.6 => 3.6
HDD-------- 4.4 => 4.4
That HDD score should increase a lot when I fit the new WD Scorpio Blue 320GB HDD tomorrow
I bet it's possible to mod the firmware of my ATI FireGL T2 128MB to increase the clocks etc (or I could just use ATI Tool or something) to increase my Graphics scores, but I don't really see any benefit in that for now
