Uh oh, sounds like you have the bad AIDS![]()
I've got a pair of hearing aids so im in double trouble...
Lady pleasing thickens them up in no time. Get to it! For even training i would suggest finding a women that can fit all five at the same time.
i doubt it would work for him it sounds like hes already over done the excersize with his brown eye![]()
Yeah... he's worn them down.
Recently after looking at my fingers, I've noticed they are getting pretty thin now. Before, they used to just be 'normal', but now the knuckles look kind of big, whilst the part where a ring would sit and the ends curves inwards now due to how thin they are. You can also see the veins in my fingers whereas I couldn't really before.
I do crack a lot so I thought it might have been down to this. However infomation on the Internet seems to suggest I'd be wrong.
What on earth can I do to make my fingers thicker and back to how they used to be? They look terrible now. :/
Thanks.![]()
Are you sure it's not just in your imagination? Do you have before and after pictures of your hands so that a comparison can be drawn?
Hilarious.
OP, hows your circulation?
Do you have any other wierd symptoms, such as unexplained scarring on your back or stretch marks for someone who shouldn't get them?
on a serious note arthritis causes swollen joints, so it could be that you knuckles are getting bigger not your fingers thinner. Any pain or RSI type symptoms? Arthritis does not just effect old people.
Too much internet, keyboard is stretching them
But in all seriousness go to your doctors this surely counts as a medical thread. Thinning of the bones (assuming that is the problem here) can be a symptom of a lot of things, some as simple as just getting older, some very nasty indeed if left untreated.
have you started to wear a pointy had and long purple velvet cloak with starts on it ?
Are you fighting the urge to grow your hair long, dye it grey and carry a drum stick around with you ?
if the answer to any of the above is yes, you might have wizarditus
