- 28 Nov 2004
- 9th Inner Circle
Whats so good about a computer that cripples upgrade potential by bunging everything behind the screen? The only thing on an imac that can be upgraded is ram, anything else is a factory only "at time of order" option. If you want more drive space that means external drives which just means more plugged into the machine, more wires dangling about (which seems to be pet peeve for jobs) and usually slower transfer rates. I also wouldn't mind seeing how hot the cpu and gpu's get in such a small enclosure on cpu\gpu heavy tasks.
I really don't see any redeeming factors in the imac at all. The only obvious one is fewer wires but that's hardly a "be all end all" issue like that tool Jobs makes it out to be.
I don't need to upgrade anything (other than adding another 4GB of RAM because Apple's RAM prices are silly) as it does what I need it to do and will continue doing that until I purchase a new one when this has reached its current lifespan. It's a tool for me. I don't want the hassle of taking it apart every five minutes to put a new GPU or whatever in it. I work in IT for my day job I don't want any of that after hours!
As for heat well I can render HD footage in Final Cut Studio (mostly using Motion / Final Cut Pro using either Apple 4444 or 4422 codecs - codecs that aren't know for being nice to the CPU/GPU) and play Portal or convert videos and as of yet I haven't heard the fan and the back of the computer gets warm. Just warm not hot.
