I have an i5 750 on a UD5 with a H50 cooler too! Have Corsair XMS3 Ram though which has a 1600MHz @ 1.65V extreme profile with 9 9 9 24 timing.
I like to make my hardware work for its living
. Running at 4GHz 24-7 - no turbo boost or speedstep which I find just adds instability for no real benefit. Settings are 20x200 with qpi ratio on 36. Mem multiplier on 8 so runs at 1600. I disable the extreme memory profile but just set it up manually.
My chip evidently isn't the best one to ever come off the production line so i need some fair volts to achieve this. 1.375 is the setting in bios, but bios and cpuz both report 1.36 at idle. Need the qpi/vtt on 1.3 which I've since discovered is naughty even though it's allowed on the almost identical i7. Mem is 1.66 as there is no option for 1.65, but bios reports it as 1.648. This is rated volts for the XMP so who cares if it's 'red' - it is set to his automatically if you enable the XMP in bios. Have tweaked the other two voltages (forget which is which off the top of my head) slghtly - 1.050 => 1.100, and 1.8 => 1.9.
Found LLC is best on level 2 for me. It may be related to a slightly less than brilliant PSU, but I find I get big droop under load if it's on auto or level 1. That means I need a huge Vcore setting in bios/idle so that when it droops under load there is still enough volts for stability. Level 2 on the other hand compensates strongly for droop - in fact to much so Vcore rises slightly under load. This is how it should be though to be honest - lower Vcore in bios/idle that rises slightly when load demands it.
This is all kept under control nicely by the H50 which idles 30-35 in a warm summer room or down around 30 in a cooler room. Load temps are 70-ish priming, and just hitting 80 during IBT, so nothing to worry about really.
Good luck.
