What kind of potatoes are uou using?
Roosters.
Roosters.
The secret is to allow the pots to steam dry after par boiling.
I think it probably was dampness from the parboiling.
Next time they'll be spot on hopefully, could do with some spray oil too.
Are you sure it's 220?! Half that time in my oven at 220 and they'd be crisp. An hour, and they'd be completely burnt.Been in an hour @220c and top shelf, and they still havent gone crisp![]()
Would using veg oil rather than olive oil make any difference?
Olive Oil is obviously healthier, but it might make a difference if you use something else.
It was only recently that I learned, from Jamie Oliver, that although Olive Oil is healthier, it actually doesn't reach as high a temperature as sunflower or vegetable oil. That's why when cooking something that needs a really quick application of heat, such as a stirfry in a wok, you don't want to be using olive oil.
In this case, you are dealing with high temperatures in the oven and want to use the oil to help be absorbed into the potato and then crisp up. I think you should be using a sunflower oil to get the best results.
Dial on 220c so yeah, electric non-fan assisted though if that makes any difference.
to make them crispy instead of crunchy
