Where can I get these wooden flooring planks?
9 Apr 2008
London
Just had a bit of an accident - a BBQ tray has fallen off and burned flooring planks a bit on the balcony.
I tried sanding it with all sorts of sand paper, but the burn looks to be too deep to be cured, so I need to replace these.
These wooden planks look pretty common, but I have no idea where to get them. I would appreciate if someone could point me to the shop where they sell them, or at least tell me what they are called, so I know what to look for.
Cheers!
Your local hardware or garden centre. B&Q for example. You might have trouble matching them in again, probably need to re-stain the whole lot as those look fairly weathered.
Looks like standard decking to me, try your local DIY stores but also visit any local builders merchants as they'll probably be cheaper there.
B&Q
As much as dislike them, they are at least open today.
Ah, that is exactly what I am looking for. Weird, but I looked at B&Q and couldn't find it. I will need to replace only one plank, so it looks like it's gonna cost me £5 and half an hour of my time. Not that bad :D
Thanks, so much guys!
If you're only replacing one plank, you definitely need to get some oil into the one next to it - that looks a little toasted too.
