Right have read up a little on water cooling, is this the right sequence for the set up -
RADIATOR >>>>> CPU BLOCK >>>>> GPU BLOCK >>>>> RESERVOIR >>>>> PUMP>>>> RETURN TO RADIATOR
I intend too custom water cool my PC (FTO1 Case / i7 [email protected] / GPU:5870) in the next couple of month's, a couple of question's as follow's -
1:What would you recommend as the minimum Pump-performance / rate of low?
2: Will a 120.3x120mm Triple Radiator(3 fan's low speed) > will this be my best option?, going to fit the radiator on the back of my case(outside)
3: Is it worth using these pre-mixed Coolent's? if so what one?
4:Can l do this with about £150? if so recommendation's on part's needed.
Cheer's, thank you > OLDPHART
