- 26 Mar 2010
- London
Corsair, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced the new Professional Series Gold AX1200, AX850 and AX750 fully-modular power supply units, with 80 PLUS GOLD certification.
The Professional Series Gold range of power supplies have been designed from the ground-up by Corsair's engineers to be the highest-performing and most technologically-advanced PSUs on the market. Built utilizing server-grade power train architectures designed for mission-critical levels of voltage stability and reliability, Professional Series Gold power supplies deliver previously unheard-of levels of performance.
[ig]http://www.techpowerup.com/img/10-05-31/114a.jpg[/img]
[ig]http://www.techpowerup.com/img/10-05-31/114b.jpg[/img]
[ig]http://www.techpowerup.com/img/10-05-31/114c.jpg[/img]
No Hotlinking!
Corsair Professional Series Gold power supplies exceed the requirements for 80 Plus Gold certification, delivering over 90% efficiency at 50% load when using a 115V AC input. This increases to over 92% efficiency when used with the 230V AC voltage input specification in Europe. Combined with an advanced cooling design, Corsair Professional Series Gold PSUs are exceptionally quiet and efficient.
To achieve these benchmark levels of efficiency, voltage stability, and reliability, Corsair incorporated numerous sophisticated server-level technologies. These include Zero Voltage Switching and Zero Current Switching technology to eliminate switching losses and reduce EMI, and individual DC-to-DC voltage regulation for the 3.3V, 5V and 12V rails. The use of secondary-side synchronous rectification and an advanced 4-layer PCB results in unusually low levels of ripple and noise.
The Corsair Professional Series Gold AX1200, AX850 and AX750 PSUs feature a fully-modular low-profile cable set. This allows the system builder to use only those cables that are needed, reducing cable clutter and maximizing airflow through the PC. All Professional Series Gold power supplies are able to continuously sustain their full rated output at an ambient temperature of up to 50°C, which means that they continue to provide outstanding performance even at elevated temperatures.
Corsair Professional Series Gold power supplies are provided with a seven year limited warranty, and are backed up by Corsair's legendary customer service and technical support.
No Hotlinking!
