GTX 470/480 Tri/Quad SLi
I have no experience of three or four card set-ups but iirc three card is where the sweet spot is. Adding a fourth card or gpu is very hit and miss.
It seems a lot depends on the res. In tom hardware review tri sli had worst framerates than dual sli in some games :eek:
This is why I reccomend the GTX470 in SLI over 5850CF/5970 even tho the single GTX470 is hard to justify.
How does a review of gtx480 in sli allow you to justify that gtx470 in sli are so good?
I;m not saying that they are not a potent force in sli, it's just that review results are lacking.
From what I can see, xfire and sli scales pretty much evenly depending on the game.
Therefore if a 5850 beats a gtx470, two 5850's in xfire will beat two gtx470's in SLI and price difference is even bigger.
The gtx 470 is overpriced, fact. Buying two doesn't make that statement any less valid.
Good to know that some positive results for quad sli or xfire are available / possible. :) In a year or so it might be quite well supported.
I do not understand why the GTX470 is so hard to justify, It can be bought for £260(Yes i know its £50 more than a 5850). If you like the features of Nvidia then fine, and £50 is nothing really.
According to the write up at the end
http://www.tomshardware.co.uk/geforce-gtx-480-3-way-sli-crossfire,review-31886-13.html
CF scaling is all over the place.
At the very worst, SLI is good for a 71% performance increase (in Just Cause 2). At the very best, it yields 89% additional performance (in S.T.A.L.K.E.R.). Three other games fall between in an impressively-close spread. It turns out that two-card SLI is a very effective way to improve the performance of a gaming machine.
The raw data might not be very indicative, but the scaling numbers are much more telling. At the very worst, CrossFire increases performance by 23%. At the very best, it’s good for a 79% boost (ironically, in Call of Duty).
Yeah, in one game which is a Nvidia title :rolleyes:
Apart from that xfire is around 70% as well.
So buy gtx 470 in SLI if you want the best performance out of Just Cause 2. Other than that, gtx 470 SLI will be slower than 5850 xfire and cost more.
I want to see proper gtx 470 SLI results. I fail to see how you can so recommend 100% as the solution to everything. Do you even own two gtx 470?
I've had my hands on them to play with... I don't own a pair.
I have sat down and benchmarked 470 SLI and 5850 CF but unfortunatly I wasn't allowed to bring them home.
Shame. There does seem to be a complete absence of decent gtx470/5850 sli/xfire with latest drivers review.
I am actually quite tempted to buy one gtx 470 with the intenetion of another one later when I go i7.
LoL toms can't even bench crysis with xfire at max rez when every other site can, says it all really, toms suck and not to be trusted.
http://www.techpowerup.com/reviews/ATI/Radeon_HD_5870_CrossFire/7.html
And now toms results..lol, I can post up many more reviews showing xfire 5870 scaling as above.
I'd love to do a review, but I'm not paying for a pair of 5850s that I'd never use myself :S
Admittedly I've only benched RE5, DMC4 and crysis but I'm convinced from what I've seen that its the superior multi GPU setup without the silly cost of a pair of 480s especially with the 256+ nVidia drivers increasing SLI performance and compatibility.
Rroff, no offense but it's no secret you're a big Nivdia supporter, I think I will stick to the impartial reviews.
Yes, thats fantastic, except Tom clearly had problems with Crysis, and he choose the worst resolution at 1920x1200 Just cause shows the same scaling between Sli and xfire, multiple other reviews show NO issues with crossfire in Crysis, Tom was just being a douchebag, 20 websites can make it work, one website can't make it work......... justifiably crap in Crysis or Tom being incompetant, is it really hard to draw the correct conclusion?
So by choose the 5870's worst resolution(because of memory) and comparing it to Nvidia's best(because of memory) and including some results that simply aren't matched by the majority of websites they show SLI has amazing scaling and Xfire to not have such significant scaling.
But this is the problem a 470GTX IS NOT a 480gtx, the 480gtx has a 15% clock speed advantage, higher memory bus and MORE MEMORY.
So Nvidia's biggest wins due to memory scaling at the highest res possible, simply won't be comparable to a 470gtx with less memory, less bandwidth and less clock speeds.
Using 480gtx sli scaling and results in extreme best case scenario is NOT remotely representative of what 470gtx sli can do.
Firstly the best case scenario SCALING will be worse because the scaling came in the worst memory situations Metro results being absolutely ridiculous are purely a memory problem, nothing more or less, several other games at 2560x1600 + 4xaa will be memory limited.
SO Scaling will be worse, on top of circa 20% worse performance in single AND SLI modes, because both cards are slower. Woo, how great are the 470gtx's.
Considering how god damned good 5870's are in xfire at a much more used 1920x1200, and how much worse SLI scales comparitively at non memory limited resolutions, the 5870cf becomes EASILY the better choice, and even better is the 5850cf which get painfully close to 5870 performance when both overclocked at an even cheaper price.
480gtx sli actually scales very nicely at high res, but is less good at 1920x1200. 470gtx sli will NOT scale the same, and pretending it will is, daft.
I'd point out that, if 480gtx's cost £300 each, I'd be incredibly tempted by 480gtx sli(or a single card), if the 470gtx cost £200, I'd be very very tempted by SLI, but cherry picking sli results to make it seem better than it is, or making xfire seem worse than it is, is simply unhelpful to people asking serious questions and decided to spend money based on your advice.
470gtx sli and 480gtx sli is great, but its NOT significantly better than xfire and not to a point that spending an extra £140 gives youy £140 higher performance.
Infact overclocked everything to within an inch of their lives, even with worse scaling 5850cf(the right ones, which admitedly are harder to come by, especially cheaply) can beat the 470gtx sli because each card is faster overclocked and though it gain less in xfire. If you increase from 100fps by 60%, you'll get better performance than two cards doing 80fps that scale at 85%, 160fps vs 148fps.
Its not about scaling %, 5850 cf offers by FAR the best bang for buck and the single most important question you need to ask from that point on is............ do 5850's in xfire provide less performance than I need, if yes, do they still provide less than you need overclocked, if the answer is yes, by all means look at faster and more expensive cards. If the answer is no, if you don't need to go from 100fps to 120fps in Metro, then why spend more than you need to?
If the situations were reversed and Nvidia were slower, but signifcantly cheaper and offered the performance you NEED for less money, I'd recommend them in a heartbeat, the only problem is, they don't.
This is why I've also mentioned a X2 type card on GF104 could enable a 480gtx performance card for a LOT cheaper and thats incredibly interesting, its all about paying for what you need. If Nvidia brings prices down so they are more expensive by the same % they are faster, they'll start being worth recommending, if they come down in price further than that, they'll be excellent buys.
Now the big advantage(and bad thing for Nvidia) is stock on shelves, few people buying and losing money, meaning Nvidia has a reason to drop prices to at least sell the things. If we all ignore the cards for another month they'll drop in price again, significantly, they might actually become a decent buy eventually.
Rroff, no offense but it's no secret your a big Nivdia supporter, I think I will stick to the impartial reviews.
What impartial reviews? the closest I can think of is anandtech and they don't really do comprehensive enough results for my tastes... TPU is certainly not impartial.
http://www.anandtech.com/show/3745/nvidias-geforce-gtx-465/
Good set of benchmarks there, unfortunatly no 470 SLI but some interesting results none the less.
Lesser cards in SLI will typically (appear to) scale far better due to being more GPU limited than CPU limited, which the top end cards often bump into with multi GPU scaling. Personally I ignore 2560x results anyway as not many people run that kinda setup and theres way too many variables such as VRAM limitations.
From my own tests, Crysis @1920 can easily go over 1024MB of video RAM, which would explain why the 58x0 cards can have strangely low results.
Anything over two cards seems very hit and miss performance wise and heat is a major issue with multi fermi set ups.
