The psu's in question are respected enough that the OP would need to be astonishingly unlucky for them all to self destruct in such time frames. Since it's only one box causing problems and the rest of them are fine, and considering how resilient atx psu's tend to be to input, the electricity supply isn't likely to be the problem.
This leaves overheating and possibly a rogue motherboard. Overheating's the more likely one if the case/airflow supports the theory, or if it's full of dust.
The first failure killed your cpu, but not the motherboard. That strikes me as unlikely, the currents will have gone through the board to get to the cpu
and motherboards are considerably more fragile than processors in general. So it's possible that the motherboard was damaged, but not killed completely. A faulty motherboard can do all kinds of mad things, killing off attached power supplies isn't beyond the realm of possibilities.
Hope for overheating, as persuading Asus to take an rma of a motherboard which seems to be working but is suspected of killing power supplies will be an experience.
Also if you X the amps with the volts, that the max surge in watts it can destroy,, and that will be 6500x6000= 39000000watts, and surges get absorbed in the batts apparently and earthed
We're discussing mains ac here, which isn't at constant voltage. As such volts x amps isn't going to get you power delivered. It's possible you can just sub in rms voltage instead and it'll work out ok, but you might need to take phase differences into consideration explicitly. Over to westom for that one.
Square waves (called modified sine waves) with spikes when powered from its battery. And that 'dirty' power is ideal for all computers
Square waves aren't modified sine waves, they're a large number (in the ideal case, an infinite series) of sine waves superimposed. Unless by "modified" you mean "adding loads and loads of other sine waves".
"Dirty power" patently isn't ideal. At best you're arguing it's sufficient for
some computers. Achievable overclock is certainly a function of power supply as well as other parameters. Which probably means that one's stable 4.4ghz processor won't be stable when running off the ups, which may be a source of concern.
If I'm being pedantic it's because you occasionally claim to be a chartered electrical engineer, and it seems strange that as such you would misuse terminology like this. I'm not very convinced by your attitude that numbers are all important either, as its not one I've seen in my colleagues or lecturers, but this may well be an eccentricity of yours rather than common across the discipline.
edit:
Just seen a post detailing the case. I'm going to say that overheating is therefore unlikely to be the problem, and put forward rogue motherboard as my best explantion for what's happening.
cos at the end of the day its false advertising and thats not allowed??
Where do you think you might be going wrong here?
