Nvidia GeForce GTX 460 Specs and Launch Date Leaked
6 Oct 2007
North West
Computex 2010: Word on the Computex show floor is that Nvidia's upcoming GeForce GTX 460 GPU will 'still run hot, but overclocks awesomely: you'll get GTX 480 performance.' We were told the card length is equal to that of an ATI Radeon HD 5770 (8.5in) but it has a 180W TDP at stock speeds.
The GTX 460 is set to have only 768MB of GDDR5 memory, rather than the 1GB of some HD 5770s and of all HD 5850 cards, and will use a 192-bit memory interface, which is wider than the 128-bit bus of the HD 5770 but skinnier than the 256-bit bus of a HD 5850. However, with only 240 stream processors, we find the claims that an overclocked GTX 460 will match a stock-speed GTX 480 rather far-fetched.
The GeForce GTX 460 uses the newer GF104 Fermi die, and parts will only launch with the Nvidia reference-design cooler at first, with custom coolers coming later. This is unlike the recent GeForce GTX 465, where partners could do what they wanted from day one. The GeForce GTX 460 will be available early-mid July.
http://www.bit-tech.net/news/hardware/2010/06/02/nvidia-geforce-gtx-460-specs-and-launch-dat/1
£200 then loooooooooool :rolleyes:
I reckon that's chinese whispers, I bet it will overclock to 480 speeds but no way will it equal the performance given the above specs unless the 104 is a total new architecture
180W TDP.
Compact PCB.
£250-300.
When did Jen Hsen leave ?
He clearly didn't, he's the master of promising things he can't deliver, sounds like classic Nvidia tactics to me.
As mentioned, it probably means 480gtx clock speeds.
Though, does anything thing it sound suspicously like a GT200b, shrunk down with dx11(you would assume) tacked on. 240 Shaders? 32 shaders in a cluster, does not compute, if it maintains Fermi's architecture, just cut down shader clusters, it would be a 256/224 shader part.
Power wise, well, it makes no sense at all, its not a cut down part so should have WAY lower power consumption. When you fused parts of the core off, theres still leakage, and some power wastage, thats why a 352shader 465gtx still uses so much power.
A core thats half the size should have really half the power, maybe even less, 180W is wrong, just completely and utterly wrong for a half Fermi part. At Fermi style clocks a core half the size should use half the power, if its got increased clock speeds, it still shouldn't use anywhere near that much power, its utterly ridiculous.
It would be very odd for them to make a significantly different midrange to top end, though how bad Fermi is from a manufacturing point you can understand it, but even if its a 16 shader cluster instead of 32, with different ratio's of rop's/tmu's per cluster, thats a massive design difference and really would have had to be designed like that WELL before Fermi had its big troubles.
I hope it's another g90 rebrand :D
It would be hilarious, but its incorrect, Bindibaghi is a complete twit, in the comments further down he's managed to say he's had the memory amount confirmed but NOTHING else, he GUESSED at 240sp's.
240sp's confirmed would have meant something completely radical, some twit guessing at 240sp's from an architecture with 32sp granularity is just that, some twit guessing something stupid.
Someone else there decided to talk himself into a 460gtx with 384sp's, decided it can be 850mhz clocks and somehow will match the 480gtx, ignoring the large drop in shaders meaning a larger clock speed would be required, and the memory/lack of bandwidth means it wouldn't get close in performance.
Seriously, bit-tech, when they review a few things do ok, but screw up constantly on other things.
Comparing every other generation, pretty much ever, the midrange part will be a half Fermi, it will have 256 shaders(if they get high yield on fully working parts of course), half the memory bus, half the memory, similar clock speeds, half the power, half the rops, half the tmu's, etc, etc, etc.
The confirmed memory being half, which confirms half the bus, pretty much to me confirms its a half Fermi, nothing more, nothing less. It will not get to 480gtx speeds, honestly I'd again put that down to someone misunderstanding something, BADLY, again.
