Having said that I'm guessing your geo is set up for handling rather than touring, so you probably have a fair amount of camber which won't be doing your tyres any good..
Actually, the wear is very even. Slightly more (0.5mm) on the edge but otherwise nice and even across the width.
I can't understand why you'd pay £480 to put tyres on a Focus when 452s would do pretty much an almost as good job (I found the difference negligible going from CS3s to 452s) for around £240.
I think the key phrase there is 'almost'. I'd be worried that 'almost' meant 'nowhere near as good'.
The reason I'm even considering the Conti's is that the car came with SportContacts on and, at the time of changing the fronts, I didn't think there was any reason to change brand. Mind you, that was then and this is now.
Thats two sets of tyres for the price of one, and the difference is minute.
From where? I'm getting quotes of around £300 fitted.
The point isn't that its just a "boggo" Focus, I've just bought four 452s for my ST.
They honestly are quite comparable to the CS3s, and when you start getting tyres for half the price, wear becomes irrelevant.
At the price point you've mentioned, they seem to come up against the Ultrac Sessantas. Any reason you didn't go for them, given the decent reputation they seem to be gaining?
All 3 are good tyres, get whichever you want.
Although you have to ask yourself whether the CS3s are worth the premium with such a high wear rate (in your case).
I'm very happy with mine, but the wear isn't anywear near as bad, perhaps because I rotate them due not having bought 4 at the same time yet..
Your point about rotating is a very valid one. The new ones went straight on the front (I know, I know...) and I'm sure I'd have got plenty more out of them had it been a set of four fitted at the same time.
mjt;16678641They're not a [I said:
premium ultra high performance[/I] tyre, but if you're on a budget and don't want the best you can get then I'm sure 452s are fine.
I'm not on a budget, but I'm not looking to throw money away needlessly. I'm after the best price
erformance ratio I can get, but I don't want to sacrifice the grip of the Conti's.
