Overdue upgrade
12 Jun 2005
Suffolk
Hi all,
It's while since my last up to date system, so thought i would give it a go.
Could you have a look below and make any recommendations where necessary.
Budget is £650 tops, i have a case, and optical drives.
many thanks
James
I would say mostly surfing the net, listening to music and a bit of gaming but i have an PS3 so use that.
J
In that case you could probably go a little cheaper on the GPU and get a 1TB HDD if you wanted it more music/films ect
Ok, cheaper on the GPU sound good. I currently have a 1TB NAS so storage is taken care of.
Looking at the spec Superewza has provided i would like to run with a modular PSU any suggestions?
Also i see the Watercooling was replaced for a fan cooler any reason why?
Thanks all
James
Thanks all
James
OCX ModXStream are generally the cheapest good modular PSUs. Not really necessary though, depends what case you're using?
Because it's just not a good place to spend money on a build with this budget. Especially with these CPUs, which are what, 95W TDP? The air cooler i specced is far cheaper and will keep temps nice and low, will probably be quieter too.
I currently have a Zalman 400w PSU, do you think it's worth sticking with that? i would need to sleeve the cables though.
And the case is a ASUS Vento A8 (Asus TA-861)
Thanks
J
Thanks
J
You could probably stick with that PSU, you know what the exact model is?
Save on that and maybe get a £60 graphics card (GT 240?) then i suggest an upgrade to the CPU and/or a new case.
Ok,
What about this, i think i would now like to keep the budget around the £580-£600 range.
Thanks
James
Hi,
Ok haven't got round to this yet, i have had to rethink the budget so it's now around £500ish. What's your thoughts on this?
With a few more post in here i can get the shipping off, that helps with the new budget :-)
Not looking for anything other than a general PC, not into gaming at the moment but as you told me to get a 4850 i have selected that for now.
Samsung F2080 20" Widescreen LCD Monitor £145.99
(£124.25) £145.99
(£124.25)
Patriot G Series 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel (PGS34G1333ELK) £88.99
(£75.74) £88.99
(£75.74)
AMD Athlon II X4 Quad Core 635 2.90GHz (Socket AM3) - Retail £80.99
(£68.93) £80.99
(£68.93)
HIS ATI Radeon HD 4850 iCooler IV 1024MB GDDR3 PCI-Express Graphics Card £79.99
(£68.08) £79.99
(£68.08)
Asus M4A78LT-M LE AMD 760G (Socket AM3) DDR3 Motherboard £51.99
(£44.25) £51.99
(£44.25)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £39.99
(£34.03) £39.99
(£34.03)
Belkin F5D8633UK4A 300Mbps Wireless N ADSL2+ Modem/Router £32.99
(£28.08) £32.99
(£28.08)
OcUK Value 300Mbps Wireless-N PCI Adapter £14.99
(£12.76) £14.99
(£12.76)
Sub Total : £456.12
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 17.50% VAT : £81.88
Total : £549.75
Thanks
James
Hello all,
So it's that question again "spec me a new rig" and as i have asked it before i thought i would continue the thread i started before.
Can someone give me there view of the following:
Gigabyte GA-MA74GMT-S2
LG W2261VP 22" LCD
Microsoft Windows 7 Home Premium
AMD Phenom II X2 555 Black Edition 3.2GHz Socket AM3
Sapphire HD 5670 512MB GDDR5
Western Digital WD5000AAKS 500GB SATAII
Tenda Wireless-N300 PCI Adapter
Startech 20 Pin ATX Power Supply To - 24 Pin Motherboard Cable
Plexus Gold Plated High Speed V1.4 HDMI to HDMI Cable Black 2m
OCZ 4GB (2x2GB) DDR3 1333MHz Gold AMD Memory Kit CL9 1.65V
Microsoft Wired Desktop 600 Black
Now not everything will be coming from OcUK so I've not included any prices but feel free to re-spec from Ocuk if needed.
I hope to also re-use my Zalman 400W PSU, that's the reason for the Startech cable. i have a case and ASUS lightscribe drive also (speaking of which what's the Win7 lightscribe compatibility like?)
Budget is £550 max
Usage is just surfing the net & listening to music.
Thanks
James
