- 24 Aug 2006
- Gibraltar
Got my 5870 up to 1030 on the core with 1.25 on smart doctor. At what point to the volts become dangerous? I want to try 1100 on the core with 1.3 but iam cacking it.
I can't help you with your issue but I just got my Asus 5870 today and I'm blown away!
I can't even think why I would want to overclock it![]()
Asus warranty their overclocking overvoltage software so your safe. I have run my 5850 at 1.35v no problem. Just keep an eye on temps.
Whats safe temp and volts? I really don't wanna break it![]()
Thats good too know. I got mine with an ek block, is yours in the same loop as the rest or separte. Thanks for the help.
If you are worried then just use the overclock feature in the ccc. I think i got mine to 900 on stock volts.
Greebo are you using smart doctor or the msi tool. Can't seem to save the overclock using the asus tool.
