It's a i7 setup. as it will have 1 x 5970 & 1 x 5870, moding the 3 fans at the bottom worries me, as i dont want hot air going over the card.
so looks like a single rad.
so a single rad will keep my chip down by 10c less then the NH-D14, even if clocked @ 4.2 ? so instead of it running at 82c say, it will be 72c
So have you compared this in tests then ?
would it be better to get the 18v pump over the 10v pump. ?
is that Thermochill PA120 rad the best single rad to get ?
Is so, could you do a kit that has an option to choice either the 10v XSPC DDC Ultra Pump/Reservoir, or the 18w XSPC DDC Ultra Pump/Reservoir
P.s. does the guide come with the kit then ?
Thanks for you're help
