Hi, I'm hoping someone can help me with a networking problem. I've been trying all morning to get my wireless routers, a Speedtouch 585 and a Tenda W311R+, to talk to each other. I'm trying to extend the range of my newtwork using the Speedtouch as my main router connected to the internet and my PC and the Tenda as a repeater bridge connected to my xbox 360 (wired) and a macbook (wireless).
I've tried setting them both to use the same mode, channel, security etc. Set the Tenda as a repeater, it finds the Speedtouch ok and the Speedtouch can find the Tenda if I switch on WDS but whatever I try the Tenda can't get an IP address from the Speedtouch. Static IPs aren't really an option because of the nature of my network, so I'm stuck with DHCP. For some reason the two routers just refuse to talk to each other.
If I switch on WDS on the Speedtouch I can select the Tenda as an access point, but I read somewhere that I shouldn't do this and only the Tenda would need WDS on. Didn't help me anyway.
I'm really struggling to see what I'm doing wrong so if anyone could help I'd really appreciate it. Might just save some of my hair as I'm close to tearing it out!
 I see what you mean about the DHCP, it wasn't enabled but I guess I should start off the range at .1? The PC's ip is static.
