SAPPHIRE ATI RADEON HD 5970 4096MB GDDR5 GRAPHICS CARD IN STOCK
17 Oct 2002
Stoke
Sapphire ATI Radeon HD 5970 4096MB GDDR5 Graphics Card @ £869.99 inc VAT
The Sapphire HD 5970 4G has 4GB of fifth generation GDDR5 memory, a total of 3200 stream processors and 160 texture units and runs with world leading clock speeds of 850MHz core and 1200MHz for memory (4.8GHz effective). The card is cooled by a customised solution from Arctic Cooling with nickel plated heatpipes and fins, featuring three low-noise dual ball bearing fans and developed specially to mate with the Sapphire original design PCB. This efficient solution also provides scope for further performance tuning. Expand your visual real estate across up to three displays and get lost in the action with ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. Among the first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals with explosive performance so you can dominate your gaming competition.
- Core Clock: 850MHz
- Memory: 4096MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 3200
- Bus Type: PCI-Express 2.0
- Display Connectors: 2 Dual-Link DVI-I & 1 Mini DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
Only £869.99 inc VAT.
ORDER NOW
i could buy 2x5970 and a couple of aftermarket coolers for the price of this card,,,grazy price,,,anyone grazy enough to buy
