*** Forza Motorsport 3 - OcUK Drivers Championship 2010 - Team try-outs***
LAGUNA SECA TIME TRIALS THE STORY SO FAR:p
1st captianfail! 01:36.374
2nd poppy 01:36.719
3rd Sp00n 01:37.264
4th utajoker 01:37.502
5th malc30 01:37.640
6th analog 01:37.829
7th Borrish 01:37.976
8th vigoro 01:38.746
9th Witor 01:38.971
10th Eliot 01:39.497
11th vonhelmet 01:39.501
12th "slinky" 01:39.503
13th Timbrad 01:40.100
14th Sam 01:40.590
15th droolinggimp 01:40.966
16th endcreditz 01:42.660
17th
18th
19th
20th
21st
22nd
23rd
24th
3rd to 7th place seperated not even by a second.:eek:
:o My bad. :p
I just went straight into the hotlap without changing anything.
I will have another go. Watch out for some rubbish times then..Cant belive I though I was THAT good...:eek:
Just clocked up a new best for me in the stock bimma.
1:41:486 Manual, ABS, wheel, f28/r27
30,820 on the leaderboards.
Still can't get all the corners correct on the same lap..... just random combinations of perfect corners filled out with atrocious ones :P
1:40.568 clean and certified at 27,414 on the leaderboard.
Now I'm getting knackered. 17 odd laps and finally something I'm happy with, even positive I can shave 1, maybe 2, seconds off that if I do another 10 laps but it's hot hot hot!
Do I need to register my interest to do this ? I would like to join in with you guys if possible. I have done some laps and i have the following time :
1:37.901, Auto, No aids, Controller, F-28.5/R-30
16,087 on the leader boards.
I was like that. I'd done about 20 straight laps, killing myself to get below 1:40, but always making at least one mistake. Then I pulled it off and I did it by half a second! I couldn't believe it! I turned the console off straightaway because I knew I wouldn't manage it again!
Got my time down to one that won't change my standing one bit, but I'm just glad to have finally broken the back of 1:40...
1:39.843 :)
I can put it down to 3 things...
1: Hit apexes properly
2: Watch this video before you hotlap for inspiration
3: Listen to this during your hotlap for that special feeling :D
01.41.229 for me.
I've just got the steering wheel so I'm still getting used to the FFB plus Im pretty poor anyway.
1:35.956
Kept getting low 1:36's but knew I could get it under 1:36.
Clean lap of laguna whilst test driving. Standard tune apart from tyre pressures. Using a pad.
You missed one from the the thread:
Put in a 1:38.943 for now, may push for more later.
My only worry is this car being upgraded into A class with Sim damage turned on, I can see people losing the rear very easily as it is fruity even at stock. The grid will be a very nervous place to sit!
His gt is rump3l4skin
YEEEEEEEESSSSS!!
Just pulled off a clean 1:38:699 :D:D:D:D
Puts me in the top 13% at 19,496. :)
Very pleased, been trying and trying for 2 days now to get under 1:39!
I'll leave it at that for now so that I don't ruin it.
So here's my official entry:
Control method : controller
Assists used : ABS + braking line - manual gears, no clutch
Tuning carried out : tyres front 30 rear 28.5
Time : 1:38.699
