As the only way this can occur, is if there is zero forward movement on the plane (in relation to the ground - assuming the treadmill is fixed to the ground).
no its not
Thank you.
no its not![]()
no its not![]()
Like how?
Like calculations of force imparted from this bearing?
You are basically saying that the wheel will turn with such speed, induce such friction in the bearing, that it will impart a force to the wheel struts that will counteract the 63,300lbs of thrust from the engines? Not to mention without ripping the wheel struts from the plane?
Edit:- It's power is relative to the air it can move through the engines, this is unaffected by the wheels
Nate
Nate
No problem, I wouldn't have posted, but it astounds me at the amount of people who don't understand the point you're making.
Some people may argue that it is semantics, some may have just missed that the question is phrased differently from the 'normal' version. Bot for a forum of people with a mainly science-based background, I'd have expected the change in wording of the question to have instantly jumped out and slapped them in the face that the answer to this question was different to normal!!
It's not different to normal, it's flawed and using fantasy physics means anything could be true and thus nothing is true, get the point yet? Either the laws of physics apply in which case it'll take off or they don't and it can do whatever the hell anybody cares to think of including turning into a bright pink four hundred storey elephant with a penchant for flip flops.
That he can choose when to turn off the laws of physics to try and prove his point as and when needed, I think most of us have got it
This is irrelevant.
The question is phrased such that the treadmill is moving at equal speed to the WHEELS (not to the PLANE).
As long as the wheel doesn't skid this will always be the case, the wheel will rotate on the track at matching, equal and opposite, speeds. You have neglected to give a frame of reference. Is this relative to the ground, the treadmill, the treadmill track, the wheel strut, the air?
Nate
I'm suggesting that with the treadmill at sufficiently high speeds the force pushing back against the axle does increase. The force isn't caused by bearing friction (that is constant) but bearing friction is a factor of it. People are assuming that the rearwards movement of the belt is all used just to rotate the wheels, this is not true. A fraction of this movement is translated into a linear force which acts through the tyre onto the axle directly. At low speeds this is not noticeable but at extremely high speeds it does become a factor. The bearing resistance is a factor in how much this force increases with speed. Given a magical treadmill capable of infinite speeds then it would be possible to provide enough movement in the belt to balance the force of the engines.
But as stated above this is all a different argument. The fact is that for the plane to move without skidding the rules of the question are broken.
No, the question is broken because it does not include a frame of reference.
This thread is scary, some people really need to learn some physics before commenting.
Regardless of how fast the treadmill goes, the plane will take off. If the treadmill goes faster, the plane's speed will be UNCHANGED, the wheels will just spin faster.
That's it, nothing else to it.
The treadmill cannot match the speed of the wheels while thrust is being applied by the engines, period. The question has been malformed and you are arguing semantics because somebody failed to type the question correctly and in doing so decided to break the laws of physics.
so the plane wont take off if the wheels are fixed speed?The wheels can't spin faster. The question states that the treadmill will match the speed of the wheels.
