- 11 Dec 2005
- Cheshire
"Ultima Hydrophobia" Intel Core i7 920 D0 2.66GHz @ 4.00GHz DDR3 H2O System @ £1,199.99 inc VAT
The "Ultima Hydrophobia" features a Intel i7 920 D0 2.66GHz processor overclocked and guaranteed to a stable 4.00GHz. With a full custom watercooling loop pre-installed the "Ultima Hydrophobia" features silent operation with ultra low temperatures allowing the processer to be overclocked to the highest standard. With a choice of the latest DX11 graphics cards you can select your weapon of choice to destroy the latest games.
Why Should You Buy This System?
- The 4.00GHz overclock ensures lightning fast processing speeds
- Massive 1TB hard drive that delivers rapid load times
- Custom Watercooling for ultimate performance and silence
- Featuring DX11 cinematic graphics
System Specification
- Case: Coolermaster CM 690 Dominator II
- Power Supply: OCZ StealthXStream II 700W
- CPU: Intel Core i7 920 D0 2.66GHz Overclocked to 4.00GHz
- Motherboard: Asus P6T Deluxe OC Palm Edition (Socket 1366) PCI-Express DDR3 Motherboard
- RAM: Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
- Graphics Card: Choice of the latest DX11 graphics cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Watercooling Specification
- Radiator: Black Ice Stealth GT 240mm Radiator
- Pump/Reservoir: XSPC Dual Bay Reservoir/pump (750lph)
- CPU Block: EK Supreme HF Nickel Universal CPU block
- Fittings: x6 Bitspower 1/2" Stubby Barbs Black Sparkle
- Tubing: x2 Masterkleer 7/16" Tubing - 1m (Total 2 metres)
- Fans: x2 Akasa Blue LED 120mm Fan (38.4CFM, 17.5dB)
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
The "Ultima Hydrophobia" provides ultimate performance, cooling and stylish looks in one awesome package. If you like to game with more power, the "Ultima Hydrophobia" is for you.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
The lead time on all pre-built systems is between 24-48 hours.
Only £1,199.99 inc VAT.
ORDER NOW
Service Package
ORDER NOW
