Big Bike Thread
Status
Not open for further replies.
I have these ones the tread pattern is little hollow pyramids and the spikes on my pedals fit in them neatly; really really grippy!
Having some problems with my gears. It won't shift onto the top two cogs, to do so I have to shift up through all the gears and then down again for it to work :confused:
Any ideas as to what can be up with it?
Try twisting the shifter's barrel adjuster (clockwise I think, so that the inside starts to poke out more) to put a bit more tension into the cable. A bit of tinkering with that should fix it.
Ive just bought a used enduro s-works 2008 ...Love the bike but unsure now on whether the medium is too small for me or not:rolleyes:
I'm 5ft 11 32 inch leg ....It seems to fit me fine ..I do feel a little over the front end.
what do you think from this crappy iphone video (sad i know:p)....does the bike look to small or not?
Hahaha I loved how you paddled the brakes for extra effect :p From the angle you do look big on the bike but it doesn't look overly small. Its really down to feel though, have you ridden it properly? Out on some trails?
Hahaha...Yeah i thought the same....Yeah ive had a blast out on it and it felt ok.
With the seat any higher though i feel far too much over the front end.
Really unsure now like comparing it to this :
Do you guys think this looks right, just installed it but i cant work out if its meant to look like that lol, followed the instructions on blackspires site so it cant be far wrong.
Bash guard? Looks ok to me, whats with the chain guide part, whats that for? Is it to maintain chain tension?
I take it you just use the middle ring at the front?
No, pictures are for the Chain guide only lol, its to stop the horrid chain slap i get, and i dont just use the middle, its a double+bash, and the chain guide is a double version. Was just a Question to see if i had the guide in roughly the right area. Oh and to stop it jumping off when it gets really rough.
Status
