[TW]Fox;16719008 said:Take the bulb out and sell it as fully working.
because the bulb not comming on is a sign of a good airbag.
He'll probably just attach the light to the injector light wires so it comes on and goes off with that.
Although given who it is I suspect the airbag is the least of any prospective owners problems.
Airbag light isn't part of the MOT, you'd never get a 306 through if it was!
Done that a few times with the ABS lights![]()
Considering there is a 'light check' when you first turn the car over . . . .
Check your plugs. Its common for the seat ones to loosen or disconnect as passengers can kick them.
