Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Just dual boot, it's cheaper, best of both worlds.
Keogh said:What's more, if you have a 27" iMac you won't find a better screen out there than that beauty!
I don't like the dock, much prefer the start menu.. i cant get used to the way you install applications, i find it hard at times to locate stuff, don't like the whole "eject" thing, don't like the way it doesnt alert you when things are downloaded or installed, i find myself forgetting I'm doing certain things because it doesn't tell you its done.
i hope that makes sense![]()
I dont like the dock, much prefer the start menu.. i cant get used to the way you install applications, i find it hard at times to locate stuff, dont like the whole "eject" thing
Surely if its unopened and unused though?Apple has a 14 day return poilcy, use that?
But tbh it took me about 20 days, the I loved it!
from hereReturns are subject to Apple's Sales and Refunds Policy. If you change your mind, you can return your Standard or Configured-to-Order hardware to us within 14 calendar days of delivery. Software returns are also accepted within this period, but only if the software package is unopened.
