Micro-SIM, do we know yet if you can simply cut down a SIM to work on iPhone 4?
3 Jan 2004
Bournemouth
Or will the phone recognize its an older SIM and reject it? :confused:
I just want to cut down my existing SIM and avoid dealing with/waiting for o2 to supply a new SIM.
Just cut it down, they are the same its just excess plastic. I don't think it makes any bit of difference to the phone size really, else it would have been in phones for years, just another "feature" for the iPhone
I've seen smaller phones with normal sims, they have the same sim slot in the iPad...
In answer to the OP's question though:
“The connectors are the same … and it has the same thing inside … it’s just that the plastic is much smaller,” said Lok8u’s Haas, adding that SIM card manufacturers slice the same cards down to one size or the other depending on which one its client requests.
^ That's form the people who make micro sims.
you can cut it down. loads of people have been doing it for ipad
you can cut it down. loads of people have been doing it for ipads
or if you really must...
you can cut it down. loads of people have been doing it for the ipad
Sorry but it really gets to me! For some reason talk about iPads and iPhones seem to bring out those with atrocious grammar!:mad:
(Yeah, stuff you if my grammar is bad too... :p)
I be cutting mine down to fit in my iPhone 4 if I buy one. I'm sure people used to do this years ago when sim cards where the same size as credit cards and moved to the standard size we use now.
Cool, so ordered the iPhone 4, talked to o2, they said as long as i registered interested in the iPhone 4 on their site, i should receive instructions on how to get a microsim before launch.
If i dont get one in time, i'll just cut my current sim up
the most unnecessary grammer nazism i have ever seen on here :p especially when all points can be debated
No, no they can't! :p
People just love leaving words out where Apple come into it. You don't say "loads of people have got desire" do you? But for some reason you do if it's made by Apple.:p
