Hi guys, a friend of mines recently bought a computer off overclockers and now it's effectively given me the I must have a new computer bug!
I'm currently running a
qx6800, 4gb 400mhz ddr1 ram, with twin Bfg 8800gtx's, I put it together myself about 3 years ago, but i've had niggly little problems with it like video stuttering, frame rate drops and similar issues so i'd like to try and avoid building the system myself again and have some kind of fallback if im having trouble getting it to run properly, I've also failed when attempting to overclock the thing too, I'd always get unstability and artifacting in games when trying to use anything but stock settings.
I was looking at the Ultima Dreadnought on overclockers and thought that would do me nicely, the only thing i've heard is the gigabyte motherboard in that has some complaints about electrical noises emitting from the capicitors need the processor socket, does anyone know if this is a common concern with with the GA-X58A-UD3R or is it a rarity?
I'm open to any suggestions, if you guys think I'd do better to buy parts seperately instead of going with the ultima dreadnought setup and not have any compatibility issues and an easy time overclocking it, i'm up for that! I've also been very pro intel/nvidia in the past, but i've been out of the game so long i'm not even sure what the difference between intels and amds are at the moment! I've a maximum budget of give and take £1,500, OS required.
Thanks!
Thanks!
