Anyone seen the adverts for these?
In case you do not know what it is:
http://www.dettol.co.uk/no-touch-handwash-system/index.php
Basically a battery powered soap dispenser that detects your hand and splurts some soap onto it.
I refer your attention to the underlined part.
Yes, you touch the standard soap dispenser but since you are going to wash your hands of the bacteria that is there anyway, so what? How many people touch the soap dispenser and don't wash their hands?
That makes this a pointless invention and a silly reason to buy one.
However, since it is battery operated, I have to get one.
Hands may come into contact with millions of germs every day. But have you ever thought about those germs ending up on your soap pump?
Fact: Your soap pump can harbour hundreds of bacteria.
Introducing the DETTOL No-Touch Hand Wash System, it automatically senses your hands and dispenses just the right amount of soap that kills 99.9% of bacteria.
Either it kills all germs, or it doesn't. If it doesn't is it simply a mechanical omission (technique, chance etc) or does it leave resistant germs that the product is no longer effective against, thus increasing resistance amongst the general population? They didn't seem to want to answer. I stick to soap and water now.
