Anyone with a zotac 9300!? Need help!
1 Aug 2003
I just installed a new psu in my sg05 and now my pc won't post, at all. All I get is the power light coming on and the cpu and chassis fans spinning! I've swapped psus and I'm getting the same thing! :(:(
I'm having to use a sh**ty laptop to post this and am unable to check zotacs site for info on the mainboard, a zotac 9300 wifi. Specifically if there is one of those diodes on the board which light up when power is going to the board. Can anyone tell me if this is the case and if so where it is? Maybe I'm missing it but I can't see anything lighting up.
Any suggestions on what it could be? Is it looking like the mobo? Oh man, I'm desperate..:(:(
There are no light up diodes on the board. If your power light comes on power is getting to the board as it comes of a header)
Do this;
Remove all non-essential hardware, this includes any external GPU, all USB devices (including the wifi card), all hard drives. You should be left with CPU, Ram and fans.
remove the PSU atx and p4 connector and re-attach them making sure they are seated properly.
set the CMOS clear jumper to clear
plug the PSU in and switch it on at the back (if it has a switch)
finally move the CMOS jumper back to normal and see if you post now.
Katch, I've done as you say, with the added faff of having the board completely outside the case and on a box, and I still getting only the power light on and the fans running.. No sounds/beeps, nothing.
What do you think? Is the board dead? Could it be the cpu?? I'm desperate here.
Hold on to your knickers! I didn't have the ram in... so I tried it with them in and hey presto! It posted!
Ok now I'm really on tenderhooks. It posted with the old psu so I'm going to try plugging the new one in. Fingers crossed. Any thoughts/suggestions anyone?
did you plug in the 4 pin atx ?
and while Katch is right that there are no lights on the board, the optical port on the backplate should light up red inside when on if thats any help :)
Huge sigh of relief... got it up and running again!
Thanks for all the help guys. Tbh I'm not really sure what the problem was but literally gutting the machine, reseting the cmos and piecing it together one componant at a time got it on its legs again.
One little niggle I have is if the onboard video is working ok? Basically I'd been using that till the last minute when I then got the video card in. Now however when I plug the monitor into the onboard video it doesn't send a signal to the monitor, tho the pc seems to start fine.. Could this be the fact that the video card is in and the mainboard/win7 is being clever and therefore not triggering the monitor via the onboard video? I've checked the device manager and I'm not seeing any faults so I'm hoping this is the case.
Anyone know anything about this?
if the board is set to the pcie slot in the bios, if you have a gfx card inserted it will always default to the card and not the onboard gfx.
