Yes folk's, another H50 thread!!!!
It's been nearly a year since the H50 was released by Corsair, since l was about to build a new rig [AUG 2009] early kit's simular to the H50 wern't all that good. I decided to pre-order one, even with their being just a couple of basic review's about them. People did not realy now how they would stand in the realworld condition's , etc, getting a proper hammering by overclocking enthusiast's , would they leak, give good temp's, how easy are they to install, etc.
Corsair had done their own promotion test ,etc, and it showed promise!!
Well l ordered my component's from OCUK + the H50x2 Apache fan's my first thought's were when they arrived were -
1.It,s black, is that it > ** rad + 2 pipe's + pump ** can it be that simple a set up, as l know nothing at all about water cooling.
2.Will it be that simple to install?
3. It was mentioned it would not block your ram slot's.
4.How long would it last, leak, etc, even though it had been well tested and given 50.000HRs or 2 year warrenty.
5.But most of all how would it perform?
I know from the basic review the H50 PWM fan was noisey and not the best performer, so decided to order 2x Apache fan's for a push / pull config.
Plus we got a proper slating of the Hard-Core Custom Water Fraturnity ** thats not water cooling it will not work, it will leak, the rad's to small for cooling never mind OC'ing ** IMAO.
Well after nearly a year my view's are -
1.Yes > It is that simple
2.Yes > dead easy to install.
3.Yes > ram slot's are free.
4.Have only ever heard of a couple that have leaked and mine is still looking good also a few noisey pump's.
5.Stock fan is ok for stock set up's but to get the best out of the H50, you need to change the stock fan, l went for 2x Akasa Apache fan's as they offered good performance but most of all their silent at max RPM which is how they ran for the past 10 month's and still going strong.
So how did it perform in the real world with me overclocking my CPU and still wanting cool temp's -
Well in my view it perform's very well my temp's with the 2xApaches [email protected] are -
Room:Temp------Core:Temp's idle [ core temp's where recorded over a fewday's]
18.0'c-----------> 28'c:31'c:31'c:32'c > +/- 1'c
18.5'c-----------> 29'c:31'c:32'c:33'c > +/- 1'c
19.0'c-----------> 29'c:32'c:30'c:33'c > +/- 1'c
19.5'c-----------> 31'c:34'c:32'c:35'c > +/- 1'c
20.0'c-----------> 30'c:33'c:31'c:34'c > +/- 1'c
20.5'c-----------> 30'c:32'c:30'c:34'c > +/- 1'c
21.0'c-----------> 31'c:33'c:31'c:35'c > +/- 1'c
21.5'c-----------> 33'c:35'c:33'c:36'c > +/- 1'c
22.0'c-----------> 32'c:34'c:33'c:37'c > +/- 1'c
To cut it short at 4'00GHz, running P95 Samll FFT's for a few hour's core temp's at 73'c:76'c:74'c:78'c varies +/- 1'c.
Resently changed one of the fan's for a Akasa Viper fan and this has improved temp,s again allowing me to run at 4.2GHz -
P95 Small FFT's temp's after two hour's -
4.2GHz Room Temp 20'c > after 2hrs (P95 12.05 > 14.07) - H50x1 Viper fan Max:2002 RPM + 1x Apache fan: Max:1400 RPM > cores at: 72'c:74'c:74'c:76'c > cores vary +/- 1'c.
So my final thought's are *** its a winner ***, but Corsair should use a better performing Fan ie: the Akasa Viper as standad, that's what l would recommend. You may ask why this thread, well over the past few month's have been looking at doing a **** Custom Water Set Up ****. On seeing the Water Cooled FTO1 by Sir Hiss that clinched it and l have ordered my part's after reading review's and also using the forum's asking the in's and out's about custom H20 cooling.
My buget was only £250 but came too £296, but hoping to sell my H50 + 2xApaches in MM to recoup abit money.
You can follow my **** Custom Water Set Up Build Challenege for £250 **** in the Overclooking & Cooling section > under ** Project:Tight Wad ** using FTO1 case.
Link to the first part of my build log, explaining how and why l chose my component's [ will update as l go along + photo's] -
Project:Tight Wad link >
http://forums.overclockers.co.uk/showthread.php?t=18154111
PS: You Can Also Put Your View's Here If You Have Owned A H50 For At Least 6 Month's ** Good
or Bad
