Threaded cylinder head - suggestions please!
Maz
Maz
18 Oct 2002
Newcastle.
Afternoon guys,
Got a scoobie as a toy, anyway taking it apart to mess about with and one thing I've noticed is the previous owner must have overtightened a spark plug and threaded the head! Anyway he resorted to tightening the plug up with some sort of sticky stuff!
Anyway do I have any other option other that resorting to replacing the cylinder head?
Thanks
Yes sorry Dogbreath, thats exactly what I mean.
I've thought about Helicoil, due to engine layout on the Impreza do you think it would be possible to fit a helicoil without removing the head?
As it's a boxer and the stripped thread is on the cylinder on nearside and the cylinder furthest from the front of the car I think this is going to be a very difficult job!
I'd imagine getting that done would need the head off?
Surely metal bits inside the combustion chamber = not good.
Defo not!
Hmmm, now I need to whip one of the heads off, renew gasket and may aswell do the timing belt while I'm there!
And I thought his Scoob was cheap!
You can helicoil a head without removing if there is enough access, you just have to use plenty of grease on the tap to hold the swarf and clean /regrease it regularly.
I imagine access is a bit tight on the Impreza is a bit tight though, removing the head would make it much easier.
Looks like I'm removing the head, doing a head gasket and timing belt aswell as new plugs and possibly coil packs :(
It's an old car and I did buy it very cheap! So I'm not too upset about having to do the work!
Defo notice a difference in performance, but not massive and it's very easy to turn off!
