- 12 May 2005
Hello,
Sometime ago lightning struck nearby taking out the computer and router.
I've had to use a backup router to get online with a laptop.
The power switch pins on the motherboard are fried but I managed to start it by shorting the pins on the back of the 24-pin socket using tin foil and glue. After several attempts and a BIOS reset it seems to be ok.
How do fix the power switch/button and reset ? At the moment the reset switch has no effect and I suspect Windows won't be able to either. The power pins have to stay shorted or it turns off.
What do I do ?
I've had to use a backup router to get online with a laptop.The power switch pins on the motherboard are fried but I managed to start it by shorting the pins on the back of the 24-pin socket using tin foil and glue. After several attempts and a BIOS reset it seems to be ok.
What do I do ?
Or take it to someone that can. Or buy a new mobo. Or RMA it like a gypo.
