- 8 Jan 2010
- London
Like the title says which would you say are the best bang for buck, bare in mind will be using in conjunction with my iphone
thanks
thanks
Ultrasone user here so cant help but the iphone 3g is well regarded by a lot of headfiers im sure Larry (headphoneaddict) gave it a very good reveiw sq wise and off course can also be used with a lod/external amp ,heres a good mixed batch of opinions
http://www.head-fi.org/forum/thread/472314/does-the-iphone-have-audiophile-sound-quality
sorry off topic and all that!!
I have a set of Etymotic Research HF5 and imo they are the best sounding earphones around,they can be had for around £70.
You can also get a set of Ultimate Ears SuperFi 5vi for £49 (The 7th result on google) which are also great value.
But bang for your buck the HF5's are excellent.
How do you think they will compare to these
Denon AH-C551 my current set. Still nothing compared to my hd 650s
im thinking about getting the Denon AH-C751, how good are the C551 ?
Personally I use Westone UM2s on my nano, excellent they are![]()
I use UM-2s and UM-1s with my iphone, both are excellent. On the go I think the UM-1s are maybe the better choice as the UM-2s are a fair bit extra and maybe are slightly less comfortable being bigger. I've looked several times though and I can't find anything else which touches them...
