need a ddr2 lga775 xfire mobo
12 Apr 2010
sevenoaks kent
got a asus p5nt currently which i didnt plan far enough ahead to sli or xfire
so i want to get a xfire capable mobo with about the same specs as the p5nt
i was thinking of going ddr3 but i dont really need massive memory power and the 4gb i got is fine! ill be running 2 5850's and a q6600 and looking to oc the cpu and memory and proberly leave the gpu running stock unless ocing in xfire is easy.
cheers
The only board worth having from here is the Asus P5Q Deluxe but it's overpriced. Have a look around for a P5Q Pro Turbo at around £95.
Yes but that's overpriced as well. You can find them for £95ish if you look.
You may want to remove the link as i believe that's against the forum rules.
yer , so how you ment to show ppl stuff lol. well im getting one 5850 then ill keep looking for the p5q till i find a cheaper one, then buy another 5850
I think you will find that your cpu will bottleneck a single card let alone a pair. E2140 at 2.2Ghz is'nt enough these days. Have a look around for a cheap second hand E7000/8000 series or even better a Q6600. Providing your mobo will take them that is.
Missed the Q6600 bit. The P5Q should get the Q6600 quite a way past 3.2Ghz. Quite a few Q6600's will do 3.6-3.8Ghz.
is that on G0 stepping tho right? and i suppose i wont know for sure till i buy it and check cpu. or will it say it on the heat spreader
will that be printed on the heat spreader? the G0 stepping part? my local cex has a Q6600 for £95 and i THINK thats G0 stepping
It will have SLACR on the heatspeader ;
i had a look, for the life of me i cant find the mm !! think im blind!!
also i get the warranty from cex, and no doubt ill have some thing to trade like my old phone for £33 so would make it cheap, and as i got my phone for free im quids in!!
