Jet wash. Simples.
Get it hand Washed?
Could do but I'd rather do it myself so I know it's been done properly![]()
Use a 5% mix of truck wash & 95% of water, Spray on with an atomiser & then hose it down with a Normal garden hose.
Once you've done that wash it by hand yourself & give it a polish afterwards to protect it.
*warning*
Truckwash is perfectly safe to use if you dilute it properly first & rince the car well afterwards. Ignore this advice & you'll damage the paintwork.
Whats truck wash?
A solution you wash trucks with, It's very aggressive though & should be rinsed like you've never rinsed anything before in your life.
Those that have seen me post my engine bays off my 4x4's will recognise it's effectiveness.
*warning*
snow foam...
