Will these Alloys fit my E36
Mebee its just the picture, but the kurbing on the 3rd wheel looks pretty nasty. If you buy them make sure that its just surface damage. Refurb can do wonders, but they wont replace metal which has been chipped away. It might just be dirt making the picture look worse than it is though.
They should fit just fine, although it is a staggered set, and its just about possible that the M3 might have rolled arches to give a few mm extra clearance for the fat bad wheels.
Had no problem fitting Staggered M5 wheels on my old E34 before I sold it though. I think BMW try to keep as much "standard" as possible between the standard and MTech cars to keep costs down.
There is little information on the actual fitment - doesn't mention wheel width, offset or PCD. I don't even recognise them as an OEM design, so for me it's a blind guess as to how correctly they will fit.
The tyre sizes are in keeping with the staggered wheel setups the later E36 M3s had, but I doubt these wheels are as wide as the original M3 alloys at the rear.
FYI original staggered M3 Evo alloys do seem to fit normal E36s without arch work - I sold a set to a chap with a lowered 320 and they went on fine.
"Tyres are in reasonable condition but not to sure if road legal or not"
Surely if the tires were in reasonable condition they would be road legal?
Thanks for the help folk... Just waiting for the seller to send some more detailed photos of the damage now. :)
